FieldPoint Family
RT target startup application is corrupt
Great!  Glad that fixed it.
Obviously, be careful if you install this older software on another PC without applying the .zip patch, because you will run into the problem again.  I suggest either upgrading your version of MAX in the future to 4.1 or higher, and/or keeping this zip file around so you can patch future installs if necessary.
-Tommy
Message 11 of 11
(1,228 Views)
