FieldPoint Family
Read a digital input with the FP-Read.vi
A possible reason for this issue could be a corrupt software installation on the flash memory of the controller. Please format the flash drive and reinstall the software on the controller (not on the PC!).
Message 11 of 16
(1,562 Views)
How can I format the flash memory of the controller?
I´ve already deinstalled the software.
There was following software installed:
FieldPoint VI-Manager 3.0.0
FieldPoint Drivers 5.0.2
LabView RealTime 7.1
DataSocket for LabView RealTime 4.2
NI-IrDA RealTime 1.0.1
NI-Serial RealTime 2.5.3
NI-VISA 3.1
NI-Watchdog 2.1.0
Is this enough or is there other software, which has to be installed?
Thank you for your help
Rainer
Message Edited by Hasl on 07-13-2005 08:31 AM
Message 12 of 16
(1,562 Views)
I´ve now formated the flash, deinstalled and reinstalled all the software.
The Test-VI for the reset doesn´t function with windows and the RealTime-Target.
Message 13 of 16
(1,559 Views)
Does that mean that now you can't access the inputs of the FP-DIO-550 neither under Windows nor und LV RT?
Message 14 of 16
(1,556 Views)
Exactly!!
But at the beginning of the topic I wrote that it didn´t work every time under windows. One time it worked and the other not. Now it doesn´t work under windows nor under RT.
Message 15 of 16
(1,553 Views)
The problem is now solved.
I don´t know exactly what had been wrong, but I created a new iak-file in MAX and downloaded it on the FP-2000. I used the same channel-configurations and channel-names as before.
Maybe there was something wrong with my iak-file I used before.
Thank you for helping me with my problem, Jochen.
regards
Rainer
Message Edited by Hasl on 07-14-2005 06:22 AM
Message 16 of 16
(1,549 Views)
