FieldPoint Family
Read range channle module
Hi
  I want reading the range module channeles in FP-1000(serial) Programmatically
(4,673 Views)
Duplicate post.
Please return to your original post for questions where someone had already responded to you.
(4,664 Views)
I want read and write range channel from fp-1000 and the module is TC module,AI 110 and AI-100 Programmatically
(4,661 Views)
Hi Spring,
Normally it is better to keep posts all on the same thread, it helps with clarity.  I believe to answer your question, you can change the FieldPoint Ranges by following this knowledge base.
http://digital.ni.com/public.nsf/websearch/E118853FBA8DFE82862572060058EA2E?OpenDocument
The Configure Range.vi seems to be exactly what you want.
Brian K.
(4,639 Views)
