FieldPoint Family
Recommen NI hardware to drive 400 solenoid valves?
Could someone recommend NI hardware to drive 400 solenoid valves in terms of price and ease of installation/wiring?  I'm developing a simple Labview control to toggle 20-40 valves at a time.  So far, I've narrowed it down to using the Compact Fieldpoint with 24x DI-403 modules.
Valve specs: 24VDC, 250mA (I may need to use flyback diodes on the fieldpoint modules)
(6,172 Views)
If you use the cFP-DO-403 you will definitely need flyback diodes across the coils of the valves.  The closer to the valves the better.  Make sure you fuse the module outputs as well.
Message Edited by centerbolt on 08-29-2007 08:54 AM
(6,169 Views)
