FieldPoint Family
Remote FTP to cFP2020
Has anyone been successful at using FTP to a cFP-2020 controller over the internet?
I'm trying to FTP to a remote cFP-2020 unit to retrieve log files that are being generated on a daily basis. This would also allow me to upload .ini files to an application that dictates which parameters are to be recorded and the speed the are being recorded.
I've have turned on port forwarding in the cable modem / router to the ip address of the cFP-2020 controller and have also opened port 21, but have not been able to establish a connection.
The cFP-2020 has been locked with a password.
My FTP software (FTP Voyager from Rhinosoft.com) does work when I'm using a pc that is connected on the local network with this cFP-2020.
Suggestions?
Thanks for any and all help...
Barty
(3,734 Views)
Hello BartyM,
The following KnowledgeBase document can give you information on how to ftp to a 2020
good luck
(3,719 Views)
sergesl,
    Thanks for the reply, but I'm beyond what these knowledge base documents offer....
    Let me try again... I able to FTP to the cFP units when on my local INTRANET. I'm trying to access the cFP units from the INTERNET.
    I have used "port forwarding" on my router to forward FTP access requests to the cFP unit's IP address. I have also opened up port 21 for FTP on the router.
    Is there something else that needs to be done?
    Once I can get this figured out, I'll be glad to post the process for the next user...
Barty
(3,710 Views)
Hi Barty,
Couple of things to try:
1.  Are you able to ping the cFP from across the Internet?
2. Try assigining a static IP (given by your ISP, for instance) to the cFP.  Does this work?
-Khalid
(3,703 Views)
