FieldPoint Family
Running application on FP 2000
Hi
i have developed an application and running the same on FP 2000. When i m running the programme on PC it runs quite well. but when i download the exe, and run on the RT controller, there are some erratic behaviours shown. There are some unwanted delays are introduced and sometimes some of the sequences are missing while the whole application is on run. Cud u plz. look into the problem and suggest me a solution.
Warm Regards
G N Srivastava
(3,368 Views)
Were you able to run your app targeted?  You may want to error-chain all the way and display the final error on the panel.  Place a copy of the executable of your app in the same place, 'C:\startup', for example, on your PC and target it.  You will now be able to look at the front-panel of the top-most VI, and hence check if there are any errors.
-Khalid
Message Edited by Khalid on 11-30-2005 01:46 PM
(3,365 Views)
