FieldPoint Family
Running out of I/O
Hello all,
I am using a cFP-2120 LabVIEW Real-Time/Ethernet Network Controller on an 8-slot backplane and I just discovered that I need more I/O-channels. What is the easiest way of fixing more I/O while retaining Real Time/ Deterministic behaviour?
Regards.
(6,371 Views)
Hello ander939,
You can add extension I/O to you Real-Time controller with the use of one of our network interface modules (the cFP-1804(4 slot) or the cFP-1808 (8slot)).  You can access the I/O from your cFP-180x network interface module with the instructions provided here.
Please let me know if you have any additional questions.
Ching P.
DAQ and Academic Hardware R&D
(6,291 Views)
Thank you Ching,
That was just what I needed!
Regards/ Anders
(6,279 Views)
