FieldPoint Family
Separating channel data from fieldpoint to perform math
Wayne, I was able to uninstall FP3.0 and reinstall FP4.0.  The "FP Read" now has the Fieldpoint IO Point function, but I can only set it to Channel 0 or 1 (i.e., there is no "All" in the drop-down box that allows me to read both channels).  Any thoughts?
Message 11 of 18
(3,922 Views)
Paul,
Try placing a new FP I/O constant from the pallete on your block diagram and see what happens.
Message 12 of 18
(3,919 Views)
I opened a new VI and created a Fieldpoint IO Point Constant, but again only Channel 0 and 1 show up.  No option for All.  Is there a way to manually override the text in the box?
Message 13 of 18
(3,917 Views)
What does MAX show for that fieldpoint module?
Message 14 of 18
(3,915 Views)
Ravens Fan, I'm not exactly sure what you mean by what MAX shows for that FP module, so here's an attachment.
Message 15 of 18
(3,912 Views)
That's exactly what I was looking for.  It only shows a channel 0 and channel 1.  So I think that is why you only have those two options on the I/O constant.  When I look at my compact Fieldpoint AI-110, I see an All and channels 0 through 7.
I'm curious as to why you don't see all 8 channels or the All considering the FP-AI-110 is also an 8-channel device.  Youd could try right-clicking on the field point in the lower part of the tree and do a Find All Devices and see if that gives you the other channels and the All.  Otherwise maybe it has something to do with that version of the fieldpoint driver.
Message 16 of 18
(3,906 Views)
pchin13,
In MAX, right click the FP-AI-110 and select Create New Item... rightclick.JPG
If you see Channel 0-7 then you have probabbly deleted some of the channels from the FP item in MAX. If you take Ravens Fan's advice and right click the Controller under Remote Systems and Select Find Devices it will find all the channels again.
Claire Reid
Message 17 of 18
(3,896 Views)
Thanks everyone for the responses.  I tried the "Find Devices" in MAX but only the first two channels appeared.  HOWEVER, I manually created an item called "All" and checked off all of the channel boxes.  This did the trick and allowed me to read all of the channels.  Not sure why everyone's suggestion of finding the devices.
Message 18 of 18
(3,888 Views)
