FieldPoint Family
Serial network on compact field point
I would like know if it’s possible to receive the serial data on the CFP 2010.
The aim:
Connect a System with Compact Field point: serial RS232 connection
Connect a Compact field point with a PC (Labview 6.0): Ethernet connection
System –(RS232)-> Compact field point –(Ethernet)-> PC (labview)
The target is simple, view the Serial data with the compact field point.
Do you have examples with Labview 6.0.
Thanks in advance
Kenyo
France
Rk: I can use the port RS232 with my PC but the port is already used.
(3,168 Views)
http://zone.ni.com/devzone/devzone.nsf/webcategories/300E64783B55DA0F8625692000618A96
TRY THIS PAGE 😛
(3,151 Views)
