FieldPoint Family
Serial ports crash on cFP-2010 using LVRT 6.1.1 and 6.1.3
I have LabVIEW RT 6.1 and cFP-2010. I am trying to write an embedded VI that will communicate with some external hardware through the serial ports, but I am not able to get the serial ports to work. Because I do not have LV7 I cannot use the VISA VIs for serial communication. I am using the old serial compatibility VIs. When it tries to configure a port (port 0 or 1) it sometimes says Error 37 but usually it just reboots the cFP module. I've tried writing new VIs from scratch and I've tried running old VIs that I had written for FP-2000 that uses the serial port, neither works. Can anybody help?
(4,015 Views)
nate,
I found this KB that may be helpful if you just recently installed LabVIEW DSC:
http://digital.ni.com/public.nsf/websearch/53B1D0482E6CF0B886256B520054352F?OpenDocument
Other than that I haven't heard of any issues similar to this. I know a lot of improvements have been made to serial/VISA in LabVIEW 7.0/7.1 as well as in FieldPoint 4.1, so if possible I would recommend upgrading.
Ames
(4,015 Views)
Thanks for the post, but unfortunately the .ini entry referred to in the KB doesn't exist in the cFP .ini.
Thanks for trying though,
Nate
(4,015 Views)
I have used the serial ports in LV 6.1 without trouble.
I would suggest you contact NI for a possible replacement of your cFP-2010. It sounds like it has a bad serial port.
Ben
(4,015 Views)
I eventually did get them to work late last night. I booted into safe mode, FTP'd to the controller, deleted all files I could, reconfigured the network module, and reinstalled the 6.1.1 software. I then edited the LV-RT.ini file and added serial.dll to the list of OnStartupDLLs. I'm not sure if the last step helped or not because soon afterwards it was removed again, but I did get my serial ports to work. Not sure why they didn't work before.
Thanks though,
Nate
(4,015 Views)
