FieldPoint Family
Setting of I P address
hello,
I am using cFp2020 field point. my field point IP is 172.25.43.2 and  my system IP is 169.254.120.091. While i am connecting this cfp through company network ie through lan it is detecting the modules. But if i am trying to connect it directly it is not pinging. i used cross cable for the second one. why is it so. i think my company has two different types of IP address.
(3,488 Views)
One thing comes to my mind:  When you're trying to connect directly, make sure your Host PC has an actual IP address assigned -- as opposed to using DHCP.  And that the two IP addresses (PC's and cFP's) are on the same sub-net.
-Khalid
(3,476 Views)
Possibly when you are connecting cFP over network,both PC and cFP are getting dynamic IP through DHCP server.
Just try by assigning static IP address to both of them.
-----Vikas
(3,459 Views)
