FieldPoint Family
Solenoid Valve Control
I am in need of some advice/help.  I have an experimental setup that requires the rapid opening of normally closed solenoid valves based on a physically measured parameter (wind speed) which I am currently measuring using the compact fieldpoint.  I took a look today at various options, and it seems that I may want to look at getting the cFP-RLY-421 along with a connector block.  Is this the case?  This module acts as a relay switch which when combined with an outside power source will open and close my valves correct?  The valves are 24 VDC actuated valves and I am assuming that the relay when connected with the valves and the power source will close the circuit and actuate the valve based on what I am telling it to do.
Also, I was wondering if there was a VI out there that specifically shows a voltage signal being generated for compact fieldpoint control of the 421 relay module?  Does any of this make sense?
In short, I just want to control some valves with my fieldpoint and I am just not 100% sure of how to do it.  Kind of like turning a light switch off and on, but automatically.......hopefully, someone can shed some light.
Thanks.
Tim
(6,522 Views)
Tim,
We spoke on the phone yesterday.  To wire to cFP-RLY-421 to supply power to your load, you will need to use the configuration seen in the attached image on the left.  This image is from the FP-RLY-420 manual from 1998.  You will have to supply a power supply to V and C, and that power supply will determine what is applied to your load.
Trey B | Applications Engineering | National Instruments
(6,509 Views)
