12-07-2012 01:17 AM
I am trying to control a Vickers proportional valve which requires a +- 10 V command signal using the cFP-AO-210 module which outputs 0-10 V. Is there a way I can switch the positive voltage to negative within labview?
Thank you
12-07-2012 12:04 PM
No, it is a limitiation of the hardware itself.
There are off-the-shelf converters, one example of such:
http://www.dataforth.com/device.view.aspx?deviceid=400
-AK2DM
