FieldPoint Family
System crash on FP-2000
Hallo!
I have found some problems using FP2000 in a stand alone application (FP 2000 + FP AI 110 + Modem connection using RS232, LV RT 6.0.3) .
After 4-5 days running correctly Operating System crashes giving 18 flashes on "status" led.
in Field Point directory, in RTlof.txt file I could read the following lines :
*** REGISTER DUMP FROM EXCEPTION HANDLER (code 18) ***
EAX = 0x00000000 EBX = 0x0074FE40
ECX = 0x00000000 EDX = 0x0074FD80
ESI = 0x00000000 EDI = 0x0074FE12
EBP = 0x0074FE28 ESP = 0x0074fb5c
CS = 0x0018 DS = 0x0020 ES = 0x0020
EIP = 0x0040f363
Thread name:
Thread stack base: 0x00730004 stack size: 131072
Call Stack:
Level 1 : Code pointer: 0x003E0F00 Stack Base: 0x0074FE34
Level 2 :
Code pointer: 0x00000001 Stack Base: 0x00000000
I believe that 'Code 18' means 18 Flashes on Status Led.
If I power of and On Fp 2000 my program can run again correctly for about other 4-5 days.
I can exclude memory problems and dinamic vectors data 'accumulation' .
Is this a bug of LV 6.0.3?
Is it possible to fix this problem using LV 6.1 ?
Regards
Luca Nitopi
(3,291 Views)
Hi Luca,
It seems to be an issue with the firmware on your module. Upgrading the firmware should solve the issue.
1. Upgrade your LabVIEW version to 6.1.
2. Get the latest FieldPoint Explorer 3.0.2 .
3. Then upgrade the firmware on your FP-2000 module
4. Make sure you choose v6.1.1 as the 'version of software to be installed on this device', when upgrading the firmware.
I hope this helps,
Pravin
(3,291 Views)
