FieldPoint Family
T1H-EBC Ethernet I/O and Labview
Has anyone written Labview VIs to talk to Automation Direct's Terminator
Ethernet I/O T1H-EBC (without using OPC Servers). Anyone have any
experiences in
using AD Terminator I/O with fieldpoint? Their device seems very similar
(in functionality) to the FP-1601 Ethernet unit. I figure it'd be similar
as the FP VI's....
Regis
(3,426 Views)
You will need to use the TCP VIs or access any DLL installed on your computer that will communicate with the hardware.
If you are going to use TCP, you will need from automation direct the structure for the TCP commands. If you do it via DLL you will need the DLL register mapping to access the DLL from LabVIEW.
Contact Automation Direct to see if they can help you with this.
(3,426 Views)
