FieldPoint Family
TPC-2006 IP
    Hello, I have a little problem with one TPC-2006, I've already set up the ip address in the network connection and then executed a regsave, so the ip address, default gateway and subnet mask for the network connection have been saved in the system image. When I reboot the network connection still have the correct ip adress but the icon in the windows task bar appears with a red "X" over it, like if the ethernet cable were disconnected. When i double clic this icon the ip address it shows is 0.0.0.0. I have to enter to the "network and dial-up conecctions" window in the control panel and disable and then enable the network conection to get connected. After I do that, the icon in the windows task bar appears connected and when I double clic it, it shows the correct ip address of the network connection. I've to do that everytime I reboot the TPC.
I don't know what is happening  so  if somebody knows how to fix this problem or what I am doing wrong please  tell me. Thank you.
This is my first post in the forum, forget me if I've put it in a wrong place.
Paul Arriz Tisoc
Mechatronic engineer
Paul
Lima-Perú
Message 1 of 1
(6,591 Views)
