FieldPoint Family
The niFPui.mxx plug-in caused an exception in the CmxAggregateItemUI::InvokeCommand function in the NIMax process. When saving *.iak file in MAX4.6
Hi There,
The subject header just about says it all. This is the first action I took with MAX - it is a fresh install. The file I wanted to save was still written and the FP seems to be working ok. However, I need to know what happened.
I can't post the whole log file due to the amount of characters allowed on this post. I can cut and paste sections if there is a specific part of the file you need. Below is the first section and last section.
Context where exception was caught:
Func: CmxAggregateItemUI::InvokeCommand Args: plugin=niFPui.mxx Item=0107EAB1 cmdID.cmdId={4A36174B-EC0C-4D73-A23D-F15D164542DE} cmdID.index=0
Application   : C:\Program Files\National Instruments\MAX\NIMax.exe
User Name     : slaney
OS Version    : 5.1.2600 (Service Pack 3)
Exception Code: C000001E
Exception Addr: 457BC448
Return Address: 457BC448
Function Name : nNIFPServer::tFpLinearScaleRange::`vftable'
Module Name   : FieldPoint71
Parameters    : F001008E 7800FDDD C5100DFC EC0107EA
Source File   : (not available)
Return Address: 481000C3
Function Name : (not available)
Module Name   : (not available)
Parameters    : 00000000 00000000 00000000 00000000
(6,357 Views)
I did a research on your error message and it seems this problem was introduced with MAX 4.6. This version switched to a new error reporting mechanism and reports even errors that are which are not critical to your task.
These errors typically show up as "unexpected" and if your error falls into this category have a look to this KB for further assistance.
If it doesn't fall into this category, your could try to go back to the MAX 4.5 or 4.4.. Of course you would need to reinstall some components and might not be able to use newer drivers at all.
Let me know.
DirkW
(6,335 Views)
