FieldPoint Family
The version of this VI downloaded on the target does not match the version you have in the project. All VIs on the target will be closed if you choose to refresh and continue with deployment.
Hi all. Let me explain my problem. I have created an application and download it into the compact Fieldpoint cFP2120. Works fine!  Then I am disconnecting my project and after connecting again I am getting a message above with few VI's from vi.lib. And each time the name and number of VI's are different! After refreshing the application stops and of course I have to start it again. How to solve it? I have tryied a masscompile, and reinstalling a FieldPoint software.
Any idea?
(6,481 Views)
Armen,
Make sure that before you disconnect from the cFP that you don't have any probes open on development machine.  Make sure that only the top level vi is open on your development machine.
(6,479 Views)
I am pretty sure that no any probes are open at disconnecting moment.
(6,457 Views)
