FieldPoint Family
Trying to use Sequence Structure to program
I am trying to program series of sequence of operation.
For example,
step 1; open valves 1, 2, 3 (time: 0sec ~ 50sec) if switch 1, 3,4,5 is closed.
step 2; open valves 2, 4, 5....(time: 51sec ~60sec) during the step 2 time period.
step 3; open valves 1, 3, 5,(time 61sec~ 75sec) if switches 1, 3, 5, 7 are closed....
Can you give me simple example.
I was trying to use "Sequence Structure" and "or array element" but not sure how to use them. If you can show simple example, I think I can follow them.
Thanks...
(3,358 Views)
This forum is meant for questions about FieldPoint hardware, or programming questions specific to FieldPoint. You would have better luck posting this question in the general LabVIEW forum. As a side note, if you search for shipping examples in your version of LabVIEW, I think you will be able to figure out how to use these.
(3,358 Views)
