FieldPoint Family
Unable to update Values in the web browser remote panel.
I am doing Temperature monitor application. In that, I am reading temperature for every one minute and drawing chart for that. After 24 hours i.e, at 12:01 AM everyday, I am clearing the chart by using propertynode with the property history. It's working fine. But in web browser it is not clearing the chart. Instead it is continiously drawing the chart. What could be the reason, Then how could I fix it.
(3,209 Views)
Suna,
I tried plotting a simple random generator on a chart and clearing it with the property node. It seems to work even in the web browser. You may want to make sure the html file reflects the current vi.
If you are able to reproduce the issue with a strip down version of you application, you can post it here and we can have a look at it.
regards,
Pravin
(3,209 Views)
