FieldPoint Family
Update Rate of AI-110
In the documentation of the FP-AI-110 the max. update rate for all channels is 5 Hz. Is it faster when not using all the channels? And do I have to turn them off?
Thanks for any help
Yves
(3,157 Views)
Yves,
The All Channel Update Rate for the FP-AI-110 module depends on channel filter settings. To achieve the maximum update rate, you should set all channels to use the 500 Hz filter option, the slowest speed will be with all channels at the 50 Hz filter option. The [c]FP-AI-110 manual provides the calculation of the update rate based upon the filter settings per channel. You can increase your speed by setting unused channels to the 500 Hz filter setting, which will result in a slightly higher than 5 Hz rate, but you can not disable channels.
Aaron
LabVIEW Champion, CLA, CPI
(3,150 Views)
