FieldPoint Family
Upgrading from a FP-1000 to a FP-1601
Good day,
I am upgrading to a FP-1601 Ethernet from a FP-1000 serial Field Point Interface. Connected to the Interface are a FP-AI-110, FP-SG-140, FP-TC-120, and FP-RLY-420 in that order. Everything works fine when I use the Serial Interface, but when I swap them and use the Ethernet Interface, my Labview 7.1 program can not read or write any data to the Field Point modules. I have made sure the modules are both named the same, but I am wondering if there is a standard procedure for this process.
andrew
(3,325 Views)
Well, after some fandangling, I got it all to work!
andrew
(3,323 Views)
Andrew,
I am glad to hear that you got it to work!  Let us know if you have any other questions.
Laura
(3,314 Views)
