FieldPoint Family
Using DHCP with a cFP-20XX across a different subnet
I have a cFP-2010 that will work great when set up with a static IP or DHCP as long as it is on the same subnet. If I set it for DHCP then move it to a different subnet, MAX can no longer find it. Do I have to use a static IP when going across subnets, or is there something I'm missing?
Steve
(3,809 Views)
Hi Steve,
You cannot browse across subnets.  See Aaron's answer in this thread for further details:
http://forums.ni.com/ni/board/message?board.id=110&message.id=207
-Khalid
(3,783 Views)
You should be able to connect by entering the IP directly, not browsing.
Matt
Message Edited by Matthew Williams on 01-09-2006 02:30 PM
(3,783 Views)
As I understand from these replies and other threads I've found is that I can only communicate (MAX, DSC, etc.) across subnets if I know the IP address; i.e., I can use DHCP, but I still have to manually enter the IP address every time it changes, so DHCP is basically useless.
Steve
(3,776 Views)
Selmore,
Not 100% sure this will work for FieldPoint controllers, but for some other NI controllers (e.g. CompactRIO) if you give a name to the controller in MAX and set it to use DHCP, then when its IP address is assigned by the DHCP server its name is registered as a DNS name. That means you can use that name to communicate to it from a different subnet. By using ping commands you should be able to demonstrate if this works for FieldPoint or not; I believe it should.
Hope my answer is clear enough and helps.
JMota
(3,761 Views)
