FieldPoint Family
Using Quad Encoders (FP-QUAD-510)
How do I use the quad to determine radian distance travelled? We are able to to determine the speed, but have been unsucessful determining how to determine radian distance
(3,399 Views)
This is dependent upon how the particular quadrature encoder you have is set up. If you know the angular speed then you should be able to figure out the radian distance from the diameter of the wheel/motor, etc.
Joji
(3,399 Views)
