FieldPoint Family
Voltage offset in FP-AO-10B
Hello All,
Im using a FP-AO-10B module for my application. Im seeing a voltage offset in NI-MAX of -0.002442 V.
Is there any way that I can remove this?
thanks,
David
(3,349 Views)
Hello David,
Thank you for contacting National Instruments.
There is no way to calibrate the FP-AO-V10B dual channel modules. The only way to compensate for this would be in software. In your case, you should add 0.002442 V to every Voltage you output to compensate for the voltage offset.
I hope this helps...
Sean C.
(3,349 Views)
