FieldPoint Family
What causes the FP-AI-110 module READY LED to flash upon power up?
The ready light flashes continuously on the FP-AI-110 module upon power up. The power light also seems to have a very short flash as well. The module part number is 184105C-01. The module has worked fine in the application for about two years. It had not been removed from the rail until this problem.
(3,285 Views)
It is most likely that a component in the FP-AI-110 has failed (or been damaged) and the module is not successfully passing the self diagnostic program. To be absolutely certain that the module has failed, try inserting the FP-AI-110 into a different terminal base and make sure the flashing Power/Ready LED's still occur in other terminal bases. You will have to contact National Instruments to arrange an RMA of the module (for repair).
Aaron
LabVIEW Champion, CLA, CPI
(3,285 Views)
