FieldPoint Family
What materials are used in the cFP I/O accesory cables?
I'm using the cables in an application that needs to know the types of material used in the Accessory cables.  Do we have any hazardous chemicals?  What is the flamability rating?  Do we have low smoke halegen materials?  What is the plating material and thickness of the pins in cables,  etc,.  Where do I get this information ASAP.
(6,052 Views)
Can you specify which cables you will be using?
The cables are normally not intended for very high voltages, so please give a description of the application as well.
Kameralina
(6,029 Views)
