FieldPoint Family
What should I do to stop the application from the remotepanel?
I download my application to the FP-2000 and publish my VI through WebPublishingTool. Requested control and gained,but I cannot stop the application from the web browser. What should I do?
(3,201 Views)
Suna,
When creating a remote front panel, the red abort button should be available. If the abort button does not work, you can also change the "Disable VI" and "Safe Mode" dip switches to on and reboot the controller. When the FP-2000 reboots, the startup VI will not be running and you should be able to remove the exe. Before creating an executable, I would definitely recommend testing your front panel as a downloaded VI. If the stop button works in this mode, then it should also work in an embedded executable.
Michael Shasteen
Applications Engineering
www.ni.com/ask
(3,201 Views)
