FieldPoint Family
What version of Field Point Explorer should I use?
What version of FieldPoint Explorer should I use? I am using LabVIEW 6.0.2. Then when I install FP Explorer, does it add the FP vi's on the LabVIEW functions palette?
Thanks for any help,
Dave
(5,064 Views)
You should use the latest version (presently 3.0.2).
When you install FieldPoint Explorer, if LabVIEW is installed, it will install the FieldPoint VIs. However, if LabVIEW is not installed, the VIs will not be installed.
If you happenned to install FieldPoint Explorer before LabVIEW, simply reinstall FieldPoint Explorer and the LabVIEW VIs will be installed.
Green Rives
FieldPoint PSE
(5,063 Views)
Thanks for your response.
I checked on NI's drivers and updates link and the latest version of FieldPoint Explorer that I could find is 3.0.1. Do they not have version 3.0.2 on their web site?
Dave
(5,063 Views)
The latest version of FieldPoint Explorer is 3.0.1. There is a patch that adds support for the FP-2015, but this is not considered 3.0.2. If you have an FP-2015 and need the patch, you can find it at:
ftp://ftp.ni.com/support/fieldpoint/Update/fp301update.zip
(5,064 Views)
