FieldPoint Family
Where can I find the safety ground of my system?
Hi, I am about to start working with my CFP-BP-x backplane. There is a safety information I have to follow. One of them is about connecting the protective earth (PE) ground terminal on the CFP-BP-x backplane to the system safety ground. Where or how I can get this system safety ground. Any assistance would be appreciated.
Dedy
(3,056 Views)
The safety ground is the "equipment ground", (the ground pin of a standard
120V AC receptacle if you are plugging your fieldpoint in, the green or bare wire
in standard US wiring practice if it is hard-wired). If you are using a PS-5 power
supply, for example, the ground pin on the terminal block should also be connected
to this ground, as should any metal box or base the fieldpoint and its power supply
is housed in.
Unless this is crystal clear to you, I would recommend getting a qualified
individual to wire up the AC power and equipment ground for your system to
make sure it is both code-correct and (most importantly) safe. Electrical codes are
pretty specific about how equipment grounds are properly connected and wired, because
a life may depend on it.
Bob
(3,049 Views)
