FieldPoint Family
Where is the iak file defined in the project?
I made changes to the *.iak file in MAX including the file name and now there are yellow bangs on the RT target and its subfolders in Project Explorer.  (The RT taget is a cFP-2110)  What is the best way to resolve this?
Dave J.
(4,192 Views)
Dave,
I lifted this out of the Fieldpoint help.  Suggest you make a backup of project before you try anything.
Importing FieldPoint Configuration Files into LabVIEW Projects
If you already have a FieldPoint system or systems configured in MAX, you can import your .iak configuration file to a new project in LabVIEW. Complete the following steps:
  1. Right-click the project name in the configuration tree and select Import»FieldPoint Configuration.
  2. Browse to the location of the .iak file, select it, and click Open.
When you import a configuration file, LabVIEW makes a copy of the file for the project and automatically saves the file when you change the project. The original configuration file remains unchanged.
(4,181 Views)
