I have a FP-1600 connected to 4 FP-TB-1 bases. 2 FP-AI-100, 1 FP-TC-120, and 1 FP-AO-210 modules. I am powering the FP-1600 with a 24 V .5 A power supply. There are no devices currently connected to any of the modules. The power supply should be supplying 12 W, which should be enough to power the FP-1600 and the 4 modules according to the power requirement calculation in the manual P = 7 W + 1.15*#modules. When I install the third module, the FP-1600 stops communicating. Checking the power supply I see that the voltage drop across the power terminals on the FP-1600 is only 11V and then measuring the current being drawn it is .5 Amps, which is only 5.5 W, not enough to power the devices. When I unhook the power supply and measure the Voltage it is 24 V.
Why is the FP-1600 dropping the Voltage to 11V? Should I just purchase a 12V 2 Amp power supply?
Thanks for any help
Jeremy
