Hi Serges
>>What exactely is your configuration (software and hardware)?
LV 6.1 with FP 4.1. There are two separate FP controllers and module sets
First hardware configuration is (FPRES1.IAK)
FP1601 controller, 1 - FP-TC-120s , 1 -FP-RLY-410, 1 - FP-AO-210
Second hardware configuration is (FPRES2.IAK)
FP1601 controller, 2 - FP-TC-120s , 1 -FP-RLY-410, 1 - FP-AO-210
These control 10 separate process stations. The main VI selects the appropriate hardware configuration and IAK file based on the process station selected in the main VI.
>>If I assume that you are using LabVIEW to build the executable,
yes
>>are building the executable with an installer
yes
>>adding the all the support files that are needed?
well that might be a point. The only files I'm including are the main VI, which calls a number of sub VIs. The sub VIs are NOT included in the list. Do they need to be if they are called by the main VI? I don't recall if these were included before or not, as it has been quite a while since I have made any mods to this system. It has been running fine for almost two years prior to the minor mod I made recently that started the problems.
>>If you go back to the previous configuration, does it work still?
No, undoing the minor change does not rectify the problem, it remains leading me to beleive it is not the code by something external to the code.
I have since tested the stand alone app on another system and it doesn't work on that one either. So that means I have two systems on which it does work and two that it does not work on, which seems rather odd to me.
It runs fine on all four systems in the development environment
Thanks for your time and effort Serges
