FieldPoint Family
cFP 2000 flashing
Good Morning
I have problem in cFP2000, it was working fine for long and now the status LED keeps blinking(somtimes continuously blinks and sometimes 2 blinks). when it is rebooted it worked fine for about a day and then the same problem coming up.
I had similar issue in different cFP last year,after a while the problem was fixed(due to pwer supply,voltage was less than 24V-after changed to new power supply it works fine) but now the voltage seems to be Ok.
Help me on this issue pls
(6,198 Views)
Veeru,
The link below is the manual for the cFP 2000.  Page A-1 displays what the LED indications mean.
https://www.ni.com/docs/en-US/bundle/370708b/resource/370708b.pdf
Can you confirm which blinking type of LED you are seeing?
You mentioned that you have fixed the issue in the passed with a new power supply.  Is that power supply still available so you can test it with this unit?
What modules are plugged into the cFP unit? Does the issue still occur if you disconnect all extra modules?
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(6,183 Views)
