FieldPoint Family
cFP-2120 & MAX 3.1.1
Hi all!
   I've tried to install software on cFP-2120 with my old MAX 3.1.1 from my WindowsXP-based PC.  When it comes to software choose, Real-Time is not shown among other options.  So I'm unable to install Real-time software (RT 7.1) on cFP-2120.  If I connect to a cFP-2020, I can correctly install Real-Time on target.
   To fix this, I've installed MAX 4.1, unistalled newer VISA and Serial RT software (RT 7.1 seems not compatible with SERAIL RT 3...), and installed older Serial RT and VISA on new MAX 4.1.
   Is this behaviour expected? Is there a compatibility list of cFP modules, MAX, RT software and drivers?
   Thanks everybody!
graziano
(6,675 Views)
Hi Graziano,
maybe this is the document you need:
http://digital.ni.com/public.nsf/allkb/B730A501736C999486256E59005A5BD7?OpenDocument
The problem could be related to Field Point driver version.LabVIEW 7.1 and 7.1.1 RT components for the cFP-21xx were introduced with Field Point driver version 4.1.1.
Clara
(6,650 Views)
Thanks Clara,
   I've updated both MAX and the drivers, now it works...
   but I'm experiencing some new problem with a new gear: VISTA + MAX 4.3 and FieldPoint, I cannot see network items, but I'll post this apart.
graziano
(6,642 Views)
