FieldPoint Family
cFP-220 Image cloning
Is there a solution to clone a cFP-2220 image?
thanks in advantage!
(4,563 Views)
the Replication and Deployment (RAD) Utility should be what you need.
Please let me know if it works!
Alessia
(4,536 Views)
i would like to recovery a image but now the controller is dead, status led is orange and any operation of reset fail 😞
(4,533 Views)
Given the situation, I'm afraid the only thing you can do is run the RAD source code and check on the error wire which kind of error occurs, maybe in this way you can figure out what the problem is. But I can assure you nothing, unfortunately.
Alessia
(4,526 Views)
