FieldPoint Family
cFP-2220 not accessing USB
Hi all,
I am trying to check if my VI is properly reading/writing a config text from a USB drive plugged into a cFP-2220.
Currently, I have the cFP connected to my computer via ethernet cord, and I am deploying it from Labview 2012.This runs fine, but as soon as I plug in the USB, the cFP no longer communicates via the ethernet cable, and the VI running on the computer freezes.
Can anyone help me with me this? Thanks.
(6,007 Views)
Does this problem happens every time you connect any USB drive to the cFP? Or does the disconnection happens only when the application is running and you connect any USB drive to it?
I did a little research and problems similar to this could happen due to versions of VxWorks, and in some other cases reformatting the disc has solve problems like this.
Thank you.
(5,978 Views)
