FieldPoint Family
cFP-AI-102 can't acquire negative and positive values together
Hello
We have found a problem when we try to acquire negative values in cahnnel 1, and positive in channel 2. Negative values are only acquired when it is alone. We have tried to change the range of acquisition of all channels to -20 to 20 V, but it doesn't works.
This can be seen using MAX (so, it's not a problem of the VI).
Can someone help? Thanks in advance
(3,316 Views)
solved. It seems that there was a problem with the sensor.
(3,313 Views)
