FieldPoint Family
cFP AI-111 compatibility
Hi, I want to replace the module cFP AI-111 and I have found one (used) that is coming from Australia. Could there be some compatibility issues?
(3,105 Views)
Check with your Compact FieldPoint datasheet if that module is compatible, you can search it on ni.com.
Also make sure the module is working correctly and is not damaged.
(3,051 Views)
