FieldPoint Family
cFP-AIO-610 outputs go high during reboot
I have a cFP-2100 with a cFP-AIO-610 and a cFP-TC-120.  Whenever I issue a reboot command from MAX, LabView Real Time project explorer or programatically in a .vi the outputs on the cFP-AIO-610 go high (10.2 volts).  This is a big problem while it is connected to my equipment.  I have the power up states of the four output channels set to 0 in the MAX configuration setup.
Has anyone had a problem like this?
Victor
(3,626 Views)
Hello Victor,
This does seem like a strange issue.  Especially if you have the power-up voltage set.  I would recommend contacting us directly for a potential fix.  This issue has been noticed in some earlier versions of the cFP-AIO-610, but has been fixed.  You can request support by going to ni.com/support or by calling a customer service representative (800) 531-5066.
I hope this helps.
Steven T.
(3,614 Views)
