FieldPoint Family
cFP-DO-401 fuses and flyback diodes
I'm using a cFP-DO-401 to control 24V valve solenoids.
On page 4 of the cFP-DO-401 manual it says to fuse the outputs with 1.5A fast acting fuses, which makes sense. But, rather than put an in-line fuse on each of the 16 wires, does anyone know of a fuse block or module that will plug in between the cFP-CB-1 module and the cFP backplane?
Also, on page 8 of the manual, it shows that the cFP-DO-401 has flyback diodes in it, but then it says NI recommends using external ones. Why are external ones needed if the cFP-DO-401 already has them?
(7,695 Views)
Mosey,
I have never seen any kind of module that installed between the backplane and the cFP-CB-1 module.  Can't imagine why NI would ever support such a device.  I like to use DIN rail mount fuse holders for this.
NI has included internal diodes to protect the cFP-DO-401 module inputs.  A flyback diode needs to be installed as close as physically possible to the coil of a relay to provide the best protection and noise suppression.
(7,687 Views)
centerbolt, Thanks for the help. Where do you get the fuse holders you use?
(7,676 Views)
Accepted by topic author Mosey
Mosey,
Here is link to one that is available from Digi-Key.  http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=277-1569-ND  Allen Bradley also makes a line of similar parts.
(7,673 Views)
