FieldPoint Family
cFP-PWM-520 channel sincronization
     Hi
             I have a cFP-PWM-520 module been controlled by Labview 8.5 but, I can not control the phase of each output channel, Is there any way to do i?, I have been trying with delays in the code but seems that the module has its own phase associated to each each channel.
 Regards
 Pedro
(7,549 Views)
By phase do you mean channel acquisition rate aka channel update rate?
(7,512 Views)
Hi, what I mean is, to control the start of the PWM signal at different time in each channel, let's say, CH0 starts at time =0 sec, CH1 starts at time = 0.003 sec, CH3 at 0.006 sec. etc. this needs to happen every 30 msec.
I need to avoid overlapping of the signals. ON time is 2.5 ms.
(7,510 Views)
(7,507 Views)
Thanks for the info Wayne.
Pedro
(7,503 Views)
