FieldPoint Family
cFP Real Time database query
I want to do a fairly simple thing.  I want my cFP to read in data, and send it to a MySQL database on a server.  The reading in of the data is easy.  The hard part is getting it to the database.
The attached .vi works fine when running on my Windows PC.  When I try to download it to the cFP, it aborts and I get the message "Failed to download DB Tools Open Schema.vi".  Now I know the cFP probably doesn't have the ODBC drivers to make this .vi work on the cFP like it does on my PC, but I was hoping that during the download, a translation would take place that would make it work.  It doesn't.
Could someone take a look at the .vi and make some suggestions on how I could get MySQL queries to work on my Compact FieldPoint?
Thanks for your help; this is a make-or-break deal for the project I am working on.  Even if you don't know the answer, suggestions are appreciated!
Synap
(4,245 Views)
Here's one option:  You obviously are running your MySQL on a PC... so, you can have a LabVIEW App on there too which communicates with your cFP VIs (via TCP/IP, for instance) and then writes that data to the MySQL Server.
-Khalid
(4,235 Views)
No, I'm running Labview on my PC, but the MySQL database is on a Linux(LAMP) server.
I know there's got to be a solution other than wasting a windows PC as a go-between in the middle of my cFP and database.
(4,230 Views)
I am pretty sure you cannot write to mySQL directly from cFP.  There has to be an intermediate entity.
By the way, LabVIEW VIs / EXE can run on Linux too.
-Khalid
(4,223 Views)
Thanks for your replies Khalid.  I guess I'll start looking into having a host as an intermediary.  I'll also have to test out some .exe's on our linux machines!
(4,220 Views)
Synap,
I think Khalid has presented the best option here. I'm not sure what a LAMP server is, but I'd try getting LabVIEW to run on it. If this is not one of NI's supported distributions, would switching be a possibility?
Ryan Verret
Product Marketing Engineer
Signal Generators
(4,210 Views)
Ryan,
LAMP just stands for Linux-Apache-MySQL-PHP, and has nothing to do with Labview.  It is a popular configuration for non-corporate web/database servers because all four components are free!  These are server applications, so the machine never 'logs in' to be able to run Labview .exes.  That's why I'm introducing a PC inbetween.
If I discover a way to run .exe as a server application, than I may revisit the system configuration.
Jake
(4,205 Views)
