FieldPoint Family
cFP-SG-140 calibration or verification requirement?
 Does the cFP-SG-140 require periodic calibration or verification? I purchased Calibration Executive 3.3 and a backplane for this purpose. There is no procedure in the Calibration Executive directory nor is there any indication that calibration is required in the user manual.
(6,499 Views)
Hi Boeing HSV,
The following knowledge base will help as far as doing the calibration within your application:
http://digital.ni.com/public.nsf/allkb/2710BD3298CFBFC686256E5A006BF67C?OpenDocument
You are right in that the Calibration Executive will not calibrate the device, however you do have the option to send it in for calibration. If you would like a qoute on this call 1-866-ask-myni.
FLash
(6,478 Views)
