FieldPoint Family
cFP2020 RS485 2-wire LabView RT
I've to connect a cFP2020 controller with a temperature controller via RS485 in 2-wire mode (tcontrollers interface- must be 2-wire). The datatransfer is done (if RS485 works ;-)))) by MODBUS protocol using RTU mode (cFP-master, CAL9400-slave). To initialize the serial port (Com4 cFP), I shortened the adequate lines on the RJ-45 connector and tried to initialize the port in LabView RT 7.1, using the Property Node Function to switch to the 2wire/Auto tranceiver mode (write). Now if I tried to run this initialization, I always got an error at property node 😞
Has anyone an idea to avoid this error message ?
(3,409 Views)
This problems is discussed here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=108199
(3,405 Views)
