FieldPoint Family
cFP2100 doesn't appear in Add Target and Devices Window
Hello:
I'm trying to create an RT Project using a cFP 2100. However, when I try to add the Target to my project using the Add Target and Devices Window it doesn´t appear there. I've configured it on MAX with no problems. I'm working with LabVIEW 8.2, LV RT 8.2 and Fieldpoint 5.0. Any ideas why this happen?
Any help is appreciated, thanks in advance.
Robst - CLD
Using LabVIEW since version 7.0
(3,800 Views)
FieldPoint 5.0 does not support LabVIEW 8.2 - you need FieldPoint 5.0.1 if you want to use FieldPoint with LabVIEW 8.2.  You can get FieldPoint 5.0.1 from the Driver CD that shipped with LabVIEW 8.2.
-Tommy
(3,787 Views)
Hey Tommy, you're right, I discovered it before re-checking this thread but I thank you so much for taking the time to answer my question. It's nice to know that people around here can help you so much.
Thanks again.
Robst.
Robst - CLD
(3,774 Views)
