FieldPoint Family
can not see cFP-2220 after creating an exe file
I am using a cFP-2220 with LabView 2011. I can see the cFP-2220 with Max, the program I created runs in my PC but the data from the cFP-2220 it is slow to up date.
I access the cFP-2220 thru the network terminal and a net card in my PC.
I have created an EXE file to run in the PC for that test stand as a stand along program. The program runs but it does not see the cFP-2220 or any of the data been collected. The test stand PC does have MAX install. When I run MAX in the stand PC it sees the cFP-2220 and can read the data from the modules the PC is wire to the cFP-2220 thru a net card.
(7,012 Views)
Hi Toro,
It sounds like you have the Fieldpoint drivers installed on the target machine since you can communicate to the cFP in MAX. Do you have the LabVIEW Real-time module installed on the target machine? You will need this for your executable to work.
(6,962 Views)
Sorry for the delay to respond... I do have installed the minimun files that are available  Field Piont 6.0.10 and LabView RT 11 is part of them.
I also using share variables. The program VI runs fine in my PC but when I create the exe file and deploy on the test stand it asks fot the location of the FPLV,dll and the NI_TGT.dll and it can not read or write to any of the DAQmx vi's.
I accidently remove one my FP-SG-140 from the list of inputs, I did put it back but I damage how the share variables weere working I am getting and error -1950679023 and it does not see any of my inputs.
I have another question how do I down load the variables to the cFP-2220 that is another erros that shows up when I installed other files into the cFP.
(6,789 Views)
My last replay I did it from home. The company internet and phone systems were down do to a damage while diggin to fix a water main.
I was able to spend some time searching NI forum and found that cFP22xx does not work well DAQmx.  I now understand why my program is running so slogish.
I have not yeat remove any DAQmx vi's, I do have share variables
The problem for the -1950679023 did not show up today the line was able to use my PC to test with no problems.
I am goin to try by removing my DAQmx to se what happens.
(6,768 Views)
