FieldPoint Family
cfieldpoint tcp/ip is stopping after some seconds
I use a cFieldpoint for my RT simulator interface.
My ethernet communication is lost after some seconds,..
I reboot cfp, start in safe mode, but still it stops after a while.
Does someone have a hint to work around this? Or is it a hardware problem?
How can I format my cFP without ehternet connection?
Have program a realtime simulator for powerplants written in C++.I translates the RT sim to NI components and software (Labview).
My rt pxi turbine simulator for simulating grid incidents was succesfully used in a nuclear plant in 2006.
Look at http://sine.ni.com/cs/app/doc/p/id/cs-755
(7,430 Views)
Hi
  As I posted earlier, I created something like a "virus", if I put a normal while loop (endless) inside a timed loop, my cFP-2020 hanfs indefinitely, and it does not respond even also to ping!!!!!!!!!! Have you got the same situation? Have you problem also in seeing the controller under MAX?
   What I saw was pretty similar to what you're reporting.....
   I'll check and report my "while loop problem" post.
   Let's discover in depth cFP's insides.... Smiley Wink
    Have a nice day!
graziano
(7,416 Views)
Here's the post I referrd to above....
graziano
(7,413 Views)
The problem is solved.
In NiMax I had to reformat the cFieldpoint, and all went to normal afterwards.
If some endless loop is run at startup, a dip switch can be set to start without the startup vi.
But even so, in my case no solution.
I think my application filled up the disc and no more space was left. So some seconds after startup the Tcp/IP connection was lost.
Because I had to reformat, I can't be sure.
But if I was fast enough, I could reformat with NiMax.
(7,145 Views)
Amazing..... exactly, how far is this nuclear plant from my house? Smiley Very Happy
  Have a nice day!
graziano
PS.: I found a problem too with disc access in FP, in fact, when the disc is full, or the drive (D : ) is absent, OS is not really happy..... it can hang for a while!  That's why I implemented a simple control of disk space left/drive integrity, which I embedded with application.
Message Edited by Graziano on 10-08-2007 08:16 AM
Message Edited by Graziano on 10-08-2007 08:17 AM
(7,126 Views)
So if it true, the solution to the problem could be:
If rebooted in NO VI, safe mode, some drive space should be freed.
So I propose a system file of some size that always exists in normal modes but is deleted during NO VI mode, safe mode.
So the TCP/IP and FTP connections could always be made in safe mode.
Message Edited by woutert on 10-09-2007 08:14 PM
(7,105 Views)
