FieldPoint Family
cfp2220 using USB keyboard
Hi all,
Does cfp2220 support USB keyboard/keypad?
 If not any other solution for the situation?
My fieldpoint is setting as Temp/RH% controller.
I would like to using keypad to vary the setpoints.
Thanks.
Robert
由 Robert LAW 在 12-27-2009 09:57 PM
上編輯的訊息
(6,561 Views)
Robert LAW-
The USB port on your cFP 2220 is only designed for storage.  The proper method to change any settings on your controller is to access it with a host computer through Measurement & Automation Explorer.  Your controller should show up under Remote Systems.  From here you have access to all the settings and parameters associated with your hardware.
Mike S
NI AE
(6,547 Views)
HI Mike S,
I design to use it as standalone solution.
by the way thanks.
Robert
(6,524 Views)
