FieldPoint Family
connection to RT engine has been lost
Hello Shimon,
Thank you  for your advice ,
Do you  mean to replace FP-2000 with FP-2015 ?
What i understood from your mail is it  is not possible to target a programme to FP-2000 more than 1MB  am i right or wrong ?
In FP-2000 booklet it shows that we can use around 11MB memory .
Please tell me a bit more about this .
Thank you
Regards
Syed
Message 11 of 15
(1,709 Views)
The available memory on FieldPoint targets depends on the LabVIEW RT version installed on the system. Please refer to this link that contains information about the memory footprint of the various LV RT versions.
While downloading the application from the LabVIEW environment there is a considerable amount of RAM-usage overhead. When you use the application builder (as tst has suggested) to build and download your application this overhead is significantly reduced and you should be able to download bigger applications.
Jochen
Message 12 of 15
(1,708 Views)
Hello  Jochen ,
I removed  'Simple Error Handler.vi' and then i tried still i get same type of errors .If possible could you please send me a small example file NPL_...vi.
This movement i am using only communication wizard not application builder.I plan to use application builder once it is working with communication wizard.
Thanks in advance
Regards
Syed
Message 13 of 15
(1,700 Views)
Hello  Jochen ,
I am using FP rela time 7.0 and my file size is around 1.68 MB .
When i tried to target (NPL_Ex_1.vi) to RT it shows error 'Download fehlgeschlagen NPL_Ex_1,vi' .
Regards
Syed
Message 14 of 15
(1,695 Views)
Hello ,
When I boot up my FP2000 it has the following memory:
Total memory 15955KB, Free memory 1284KB.
Why it shows too less free memory .I think free memory should be > 5MB.
Thank you in advance
Regards
Syed
Message 15 of 15
(1,683 Views)
